Posted by pete 23 on June 30, 2010 at 18:49:44 from (173.87.147.99):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Just to add to what Sam said, turn engine until points are open, then you should get a test light to light up on both side of coil, + and -. If you do not get a light, you have an internal ground like condenser or lead wire is touching side or you do not have continuity through primary winding of coil. That is easy to find out by unhooking wire to points and if you get a light then you know current is available through coil. If these things check out, what I do is, pull high tension wire out of dist cap, with switch on and points still open , all wires hooked up, merely make and break contact of the terminal at points or coil with a screw driver or what ever, which will simulate points opening and closing, and you should get a nice healthy spark to a good ground out of that high tension coil wire. Tells you if coil and condensor and all wires leading to it are good.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
