Re: 400 leaky rear hydraulic coupler tubing
Posted by pete 23 on June 30, 2010 at 18:55:43 from (173.87.147.99):
In Reply to: 400 leaky rear hydraulic coupler tubing posted by Don Hopf on June 30, 2010 at 13:50:56:
You can get a fitting crimped onto a hose that has compression fitting that will slip on the good portion of the pipe, or you can go directly with threaded elbows into back of hyd valve and hose all the way but that is not so easy or like poster said, go on e-bay.
