Posted by Brian Schmidt on June 30, 2010 at 20:31:56 from (69.66.237.6):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Need to find out if you got spark or not. When you say no fire I assume you mean it wont start. Pull the wires off at the dist and check contnituy to ground. Should be nothing when the points are open and a direct short when closed.
Then if that is good move onto the coil. If you are 12v neg ground then it is neg side of coil to the dist. And a hot switched wire on the pos side. If that is all good and you still got no spark, pull the condenser out and try it again. Could be shorted. If that still gives nothing, then replace coil.
If you are 6v pos ground, then switch the pos and neg directions on the coil for optimal performance.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
