There is a shelf in the belt pulley that allows excess oil to go the transmission. You could fill everything but the engine, hydraulics, and IPTO rear unit from there. Unless you have a barrel pump, it will be easier to empty the 10 gallons of Hy-Tran into the filler hole on the rear frame cover. If you are not going to use the belt pulley in the near future, oil will eventually splash onto the shelf and it will self-fill.
The center section and rear frame are connected by unshielded bearings. Oil will pass from one to the other. Yeah, there are two level plugs but I don't know why. There are also three drain plugs. Drain all three.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
