Super M hydraulics ports
Posted by Nevada Dan on July 01, 2010 at 08:56:24 from (12.213.224.36):
I"m adding a 3-pt kit to my 1953 Super M (S/N L509427J), a Stage II, I believe, with the distributor pump and the cast reservoir (P/N 358444R1) under the gas tank. Question: What are the bulges with ports in the cast rear plate of the reservoir? The top one is obvious - it"s plumbed and hosed forward to a T that feeds outlets to both sides midtractor for lift-only (loader, etc). What is the bottom bulge with two plugs (left and right)? Are they pressure and return? Can I use one and plumb it to the rear for lift-only function on my 3-pt? Or should I just T into the upper line I know is pressure, lift-only? For future reference, where do I find a description of the valve functions and ports inside this reservoir??
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
