Posted by Janicholson on July 01, 2010 at 09:00:31 from (199.17.6.23):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Put it together except the distributor cap and rotor. Put the coil wire (cap end) near the block and tape it so it stays near the block 1/8" will do) use a plastic handled small screw driver to touch the rubbig block of the points, weaseling them open. If you get a spark, and the points are gapped when the cam has them max open, it should run. If no spark, the points are grounded or the condenser is shorted, or the stack of washers and insulators is shorted to the distributor housing. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
