Re: IH 544 - dumping gas??? - HELP
Posted by Janicholson on July 01, 2010 at 13:58:22 from (199.17.6.76):
In Reply to: IH 544 - dumping gas??? - HELP posted by sunuva on July 01, 2010 at 12:28:07:
I will say if it the Crank Case Breather Tube shown, do not run the tractor at all.
The previous fuel pump may have been bad, and allowed a leaky diaphram to fill the crankcase with gasoline. This is not only explasive, but ruins the engine.
Drain the oil just a little and see if it smalls like gasoline, if so it needs to be changed right now.
Also always turn off the fuel valva at the tank to assure this never happens again. It is a standard operating policy with all these tractors. Jim
