Re: IH300 Utility - Changed Hydraulic Oil, now problems?
Posted by Andrew Z on July 01, 2010 at 16:52:37 from (64.252.148.52):
In Reply to: IH300 Utility - Changed Hydraulic Oil, now problems? posted by ChrisNH on July 01, 2010 at 16:44:04:
First off, you want to use HY-Tran equivalent oil, TSC oil is ok, but i do think you have the wrong one in there now. As for the leaking sounds like you have a seal out in the pump allowing oil to get to the dist / tach drive.
Andrew
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
