Re: Problem with Sickle Cutter Pitman Arm, (tractor= Farm...
Posted by Brownie 450 on July 01, 2010 at 18:59:28 from (66.43.241.95):
In Reply to: Problem with Sickle Cutter Pitman Arm, (tractor= Farmall H. posted by Farmergeist on July 01, 2010 at 18:22:18:
I had the same trouble. I put a hose clamp around the ball clamp so it would hold tight. That release "thing" that they had on the end of the pitman stick was a big joke. Make sure the sickle is sharp--will pull a lot easier.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
