Re: Problem with Sickle Cutter Pitman Arm, (tractor= Farm...
Posted by F-Dean on July 01, 2010 at 19:09:07 from (75.205.90.75):
In Reply to: Problem with Sickle Cutter Pitman Arm, (tractor= Farmall H. posted by Farmergeist on July 01, 2010 at 18:22:18:
What are you trying to cut? A sharp sickle is a must if you are cutting Buffalo grass.
Today's Featured Article - Memories of a Field Service Engineer - by Brian Dye. I worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 I became a dealer manager and finally left the dealer net in 1975 to run my own electronic design and manufacturing company called BHE after the old 16th century Inn where we are now based. We specialize in agricultural electronics working in the past for Claas, Grimme, Standens and Reekie on combines, potato and sugar beet har ... [Read Article]
