Re: farmall h hydraulics/kill switch
Posted by Janicholson on July 01, 2010 at 19:54:37 from (64.61.211.174):
In Reply to: farmall h hydraulics/kill switch posted by sunaewayha on July 01, 2010 at 19:19:26:
third party image
This will help on the hydro. just wire back the control rod to keep it on. Not a problem (the pump is on all the time the clutch is out any way)
The stock kill switch is a single terminal push pull switch that grounds the mag to stop it. The switch body is the ground. If any single pole single throw switch is used, it needs to have one of the two terminals grounded with a short wire. Never put power to a mag, they make their own. Jim
