Posted by Owen Aaland on July 02, 2010 at 00:58:44 from (65.161.86.20):
In Reply to: H stuck on TDC posted by rmthunder on June 30, 2010 at 20:22:20:
When the starter locks the engine the problem is worn teeth on the drive and possibly also the ring gear. Usually replacing the starter drive is enough to correct the problem. If there are teeth burred over on the ring gear you can make it serviceable but filing off the rough areas. Just make sure the surface that the drive pushes against is smooth.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
