Re: Firecrater pistons revisited
Posted by Brian Schmidt on June 03, 2000 at 17:54:32 from (207.179.196.33):
In Reply to: Firecrater pistons revisited posted by Joe/WI on June 02, 2000 at 13:37:04:
Do what you want to. But if it was mine, I would check it. It only takes a few minutes and could save you several hundred $$$. The time it has taken you to decide weather you should do this or not, you could have done it many times over.
Put the clay on the piston head and rotate the engine over at least 2 times to open both valves. Go 3 or 4 or more. Bolt it down snug. Rotate it by hand only!!! This won't allow you to break anything. Then check the thickness of the conpressed clay. I wouldn't feel comfortable with less than 1/8".
Post A Followup
: Re: Re: Firecrater pistons revisited
