Re: 1949 M Gallops at high speed
Posted by janicholson on July 02, 2010 at 06:18:45 from (199.17.6.76):
In Reply to: 1949 M Gallops at high speed posted by Gerald Anderson on July 01, 2010 at 18:34:49:
Jack up one side and block it up. chock the other side, and set that brake. put a concrete block next to the tread 1/2" away from the raised tire, and spin the tire in the air by hand to see if the tire is out of round 9runout) if so, more than 1/4", I would next check the rim runout to see if the clamps were tightened crooked. Use a piece of steel rod, or a broom stick across the concrete block to be near the rim flange, again looking for deflection from round.
If none, do the other side. Jim
