Re: Problem with Sickle Cutter Pitman Arm, (tractor= Farm...
Posted by Dave H (MI) on July 02, 2010 at 07:14:58 from (205.188.116.73):
In Reply to: Problem with Sickle Cutter Pitman Arm, (tractor= Farmall H. posted by Farmergeist on July 01, 2010 at 18:22:18:
OK...so you want to keep the mower so my opinion that the older pitman mowers are interesting only for show restorations and swim raft anchors is not wanted.
JD mowers of that age, and my experience is with the semi-mounted #5 mowers (thinking yours is likely similar), had two cups that clamped over a ball on the end of the knife. Balls may or may not have zerks in them...seen both. Cups are held on tight with a "T" shaped part (fork) that has a heavy coil spring on it's shaft. Make sure it is all there and the spring is holding tight. Cups and knife balls can wear out. I have seen cups worn to a knife like edge. My best luck has been with good cups and the ball with the zerk. Check your parts for wear and get the manual and make sure it is set up right and sharp so that you are not overstressing the joint. HTH, Dave.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
