Posted by RustyFarmall on July 02, 2010 at 07:27:31 from (209.152.78.140):
In Reply to: Gov Weight Pins... posted by CoopertownBob on July 01, 2010 at 20:24:27:
On a couple of my Hs,I used some 1/4" long shank bolts. Make sure the shank on the bolt is long enough to pass through both the bracket and the weight. Cut off the threads so there is just enough left install a nut, carefully tighten down the nut so you don"t limit the movement of the weight, and then either tack weld or stake the nut so it can"t loosen up. If I remember right, I had to use a dab of valve grinding compound on the shank of the bolt to "fit" it to the hole in the weight.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
