Re: Problem with Sickle Cutter Pitman Arm, (tractor= Farm...
Posted by RustyFarmall on July 02, 2010 at 07:41:13 from (209.152.78.140):
In Reply to: Problem with Sickle Cutter Pitman Arm, (tractor= Farmall H. posted by Farmergeist on July 01, 2010 at 18:22:18:
I agree with what the others have mentioned, but you also need to make sure the sickle bar is "timed" to the mower bar. In other words, when the sickle reaches the end of the stroke, the mower sections need to be exactly centered in the mower guards. Your owners manual will show the procedure. Also, the far outer end of the mower bar needs to "lead" the inner end, i.e, the outer end should be ahead of the inner end. Again, the owners manual will explain it. I spent most of my youth riding on an H Farmall with a John Deere #5 hay mower attached. There just isn't any combination that works much better until you get into the much newer style of mower.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
