Re: None Running 350 utility
Posted by old on July 03, 2010 at 09:23:42 from (4.245.6.31):
In Reply to: None Running 350 utility posted by Bryce Burden on July 03, 2010 at 09:00:32:
Sounds like your throwing parts at it before doing any real trouble shooting which by the way is not the way to fix things. First thing you need to do is check for spark, you need a blue/white spark that will jump a 1/4 gap or more. No spark no run. If you have no spark hot wire it by running a wire for the hot side of the battery to the ignition side of the coil and check for spark. If you have spark when hot wired you have a problem from the coil back to the battery if still no spark your problem is in the distributor and you point maybe bad or they slipped
