Re: 1949 M Gallops at high speed
Posted by Janicholson on July 03, 2010 at 20:44:50 from (64.61.211.240):
In Reply to: Re: 1949 M Gallops at high speed posted by G. Anderson on July 02, 2010 at 14:11:39:
If you mark the tire with a piece of tape, the location of the tape can be seen when the tractor is driven down the road galloping. When the tractor is "up in its motion, note where the tape is. Stop, and move forward until the tape is in that position. now the light side of the tire is on the ground. Adding weight to the rim at the down side will help balance it. The wheel weights are not part of this discussion. Putting a pound of weight on the inside of the rim, by bolting on material that will not come off will attempt to balance the wheel. It will take time to get it right, but it should balance. When it smooths out, you can decide how to make it look better than bolted on plates (if you care). Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
