Re: 350 Utility change to IPTO
Posted by Wardner on July 04, 2010 at 05:24:04 from (4.154.237.106):
In Reply to: 350 Utility change to IPTO posted by MeanGene1 on July 03, 2010 at 21:31:38:
The key to your problem lies in the serial number suffix. Sounds like it has a "R" which is TA attachment with provisions for transmission driven PTO. If the serial number ends with "P" or "S", just do as you initially suggested.
If you want IPTO, buy another tractor cheap (needs work) with the "S" suffix. Use the center section and rear section.
This will work but you may find that the IPTO will not run at the proper speed (540 rpm) if buying a row crop. I think the IPTO driven and driving gears are different between the models. You will have to check the parts books.
You need to understand that the IPTO gets its power from the clutch pressure plate. The transmission PTO gets its power from the constant mesh gear and countershaft in the transmission. This changes alot of parts. The easiest solution would be to swap your Diesel into a "S" suffix Utility with a bad engine
Click below for on-line parts books.
CaseIH parts book.
This post was edited by Wardner at 08:35:21 07/04/10.
