Have you checked the differential itself? If you havent used the tractor in a while, you can try to loosen the drain plug just a little and see if water begins to drain out. Drain down the water as much as you can, if there is any just sitting there. It may help stop the leak for a little while, since it lowers the level of fluid in the rear end.
However, that wont fix the leaky seals problem.
I also pulled all my deck bolts and put a neoprene washer underneath to try and help seal out any water, might be worth a try in your case.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
