I am just a driveway farmer so not used regularly. I bought the tractor 15 years ago. The first winter I tried to use the tractor I discovered the water. The rear end was frozen, couldn't back out of the barn. Removed the plug and there it was. Ice shaped like the inside of the plug. I replaced the lube then. I usually leave in barn but sometimes not room because of other stuff. I'll try the washers and clean out the barn. Thanks
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
