No rules here on that topic. If the governor output shaft (and linkage is not moving, you are going to need to go into the governor. Do not allow it to run over speed, as there will be drastic damage. If the link from the throttle control lever is moving the lever on the governor through its full range, it is internal to the governor. They can have any problem from broken springs to bad bearings, to weights off of the spindle. A manual is needed. caseih.com has a parts diagram on line. Jim
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
