Posted by ScottyHOMEy on July 04, 2010 at 13:33:29 from (64.222.248.253):
In Reply to: Ignition Switch posted by Bud W on July 04, 2010 at 13:18:52:
The housings and buttons look the same, Bud. What differs are the guts.
For a battery ignition, it's a double-pole switch. There are two connections on the bottom of it, both insulated from ground. One is supplied from the battery. The other runs up to the ignition coil. With the mushroom-cap switch button in the down position, the connection between them is broken/open, so there is no juice running to the ignition. With the switch button in the up/run position the connection is closed , so that there is juice to the coil to fire the ignition.
On a magneto, there is only one terminal on the bottom of the switch. And the switch makes or breaks a connection between that terminal through its own case to ground. A single wire connects that terminal to the side of the magneto. In the down/stop position, the switch is closed, making a connection between the mag and ground, so it cannot run. In the up/run position, that connection is broken and the electrical system within the mag has no steady, unrestricted connection to ground, and is free to do its magneto thing.
Despite their quick-glance similarities, the two switches are entirely different animals.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
