Re: 544rc solenoid fuel shut-off valve
Posted by Janicholson on July 04, 2010 at 16:39:32 from (64.61.211.84):
In Reply to: Re: 544rc solenoid fuel shut-off valve posted by yooper Tim on July 04, 2010 at 13:19:20:
Check the distributor cam for wear in its bushings (side to side/Up and down, not in and out)
if any play can be felt, or measured, it must be less than .001" or timing will be very erratic, leading to the described running problems. The points need to be set to .020"
Good luck. Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
