Re: 350D filters
Posted by Wisconsin Cowman on July 04, 2010 at 18:27:02 from (98.115.11.159):
In Reply to: 350D filters posted by MeanGene1 on July 04, 2010 at 14:07:42:
Wix filter part numbers
Final Fuel Filter
33191
Primary Filter
33102
Secondary Filter
33101
They changed the fitting sizes final filter I think so you may have to make a new fuel line or different fittings.
If you want the oil filter number it is 51006.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
