Posted by Tom Fleming on July 04, 2010 at 19:28:32 from (206.193.253.243):
In Reply to: Ignition Switch posted by Bud W on July 04, 2010 at 13:18:52:
You can make a distributor IH switch run a mag, but you can't make a mag switch run a distributor.
Mag switch = 1 terminal on the back
Dist. switch = 2 terminals on the back.
If you want to make a dist switch work with a mag, run 1 terminal wire to ground, and the other terminal wire to the mag. then, you will push it in to run, and pull it out to shut off. Kinda hokey, but I have done it in a pinch until I was able to get the correct switch.
so, depending upon what type of switch you are buying, will make a different only if you have a distributor ignition. If you have a mag, doesn't matter unless you want to be "correct".
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
