Re: 544rc solenoid fuel shut-off valve
Posted by yooper Tim on July 05, 2010 at 06:13:25 from (74.221.53.215):
In Reply to: Re: 544rc solenoid fuel shut-off valve posted by Erik Dekeyser on July 04, 2010 at 16:21:12:
Re: 544rc solenoid fuel shut-off valve in reply to yooper Tim, 07-04-2010 11:05:22
The reason i'm thinking the fuel solenoid is that the wire to the solenoid was shorting out on the solenoid cassing and I saw smoke from that area.
I changed out the points, rotor, condensor, dist. cap, plugs, wires, and coil, with no change in performance.
I removed the air intake to the carb looking for excess gas and found it dry. Does that answer the needle and float theory?
Will check later, gotta feed critters.
