Posted by Archie McArdle on July 05, 2010 at 09:31:44 from (98.112.167.215):
In Reply to: 454 oil usage posted by Ranch Hand on July 04, 2010 at 15:16:28:
I'm with Locojim . Using Air holds to keep the valves in position , or stuffing a rope in the cyl thru the spark plug holes , you can jam the valves in the up position , and install valve seals on the valve stems. It's pretty easy , and worth a shot before a big teardown....
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
