Re: 454 oil usage
Posted by Janicholson on July 05, 2010 at 12:55:30 from (199.17.6.76):
In Reply to: Re: 454 oil usage posted by locojim on July 04, 2010 at 19:35:40:
If the blue smoke is only present on idling conditions, or on down hill runs in high gear, yes it could be guides. Blue and stinky seems to me more likely to be stuck rings. Either way it should have a valve job when rebuilt. Jim
