I"ve got a set of used brake bands from an H. I"m not sure if they are original bands or not, but they definitely are NOT of the current aftermarket variety, and they DO NOT have the brackets riveted to the bands. The brackets are spot welded on. The lining IS riveted to the band. I"ve also got a set of brand new brake bands for an H, as well as a set for an M. The brand new bands for the M DO HAVE the brackets riveted on, but the new bands for the H have the brackets spot-welded on, just like the old, old set. I strongly suspect that the original H bands had the brackets spot welded on also.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
