Re: IH 1066 PTO issues
Posted by The tractor vet on July 05, 2010 at 13:59:28 from (76.212.231.173):
In Reply to: Re: IH 1066 PTO issues posted by JMY on July 05, 2010 at 12:13:12:
Well the big round thingy is probably the brake drum . So i am guessen that either the seal on the bull pinion is leaking or the brake piston is leaking . And yea i and a weeeeeeeeee bit north of Texas and a tad east also . i am in N.E Ohir . To check PTO pressure ya need a special fitting and a gauge that will go to atleast 600 lbs . Lock up pressure should be between 235 and 265 . I like setting them at a the higher end of scale . IF it only needa clutch pak that ain't to hard of a job but ya need a cherry picker to handle it as it is heay and ya have to tip the back down so ya do not bag the pick up tube as you come out . Removal of the three point top link bracket makes it a lot easier to watch the shaft as you come backout . Myself i would install the Hd clutch pac with the 7 and 9 set up . Now if it needs a total rebuild then well ya need a FEW special tools to do this . Takes about 3 1/2 hours to rebuild one and maybe 4 if it fights ya . Just did a 1086 for a friend a week ago . That one fought me all the way . Now i am going back outside with a vary cold barley pop .
