Farmall Tractors Discussion Board
Answer for Peter on W4
Posted by Harold H on January 01, 1999 at 08:10:00:
Peter,
In 1952 the standard tire size on the W-4 was 13x26 rear and 15.5x16 front. Factory options were; 12x26 rear and 6.00x16 and 6.50x16 front. The W4 had a 152.1 cu in engine and was tested in Nebraska test number 353(gasoline) 26.21 max belt hp, 23.97 max db hp, max pull 3671 lbs @ 2.16 mph. Corrected to sea level 27.89 max db hp and 25.67 max db hp. The W-4 is the wheel or standard tractor version of the H.
Harold H
Post a Followup
: Re: Answer for Peter on W4
