Posted by janicholson on July 05, 2010 at 15:15:59 from (199.17.6.76):
In Reply to: IH 424 (gas) wiring posted by mike tn on July 05, 2010 at 13:10:25:
I will try. The voltage regulator is in the alternator, so if you removed "a" voltage regulator, I will assume it is not the voltage regulator. The alt light should have one terminal connected to the ignition switch terminal that goes to the coil. The other Alt light connection goes to the #1 terminal on the edge of the alt. The oil pressure light hooks to the oil pressure switch on the block, and to the same ignition terminal as the alt light. The #2 terminal on the Alt hooks to the big output stud on the Alt. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
