300 utility
Posted by tomnj on July 05, 2010 at 17:23:03 from (68.167.68.71):
Just got done putting on my new manifold and exhaust(started right up and ran great) after about an hour of brush hogging my oil pressure was down to 5lbs. Parked the tractor took off the fitting in the block and put 50lbs air pressure to the fitting and the guage read the correct 50lbs. Oil level is fine. Am I looking at a new oil pump? or is there anything else I can try?
