Re: IH 460 wont start
Posted by pete 23 on July 05, 2010 at 21:38:57 from (184.12.35.20):
In Reply to: IH 460 wont start posted by 460guy on July 05, 2010 at 17:40:56:
600 rpm cranking speed , holy cow, you could plow with that. Min cranking speed is way less than that. Make sure you are continuing to hold glow plugs while cranking as they cool off in about 5 seconds with fuel shooting on them. Compression is everything to having them start along with good cranking speed. The 460 always was minimally equipped when it comes to a starter. You need good heavy cables and lots of ampere hour battery capacity. If it runs ok one started, fuel to and back from pump is not the problem, but if it doesn't it may well be. Even a slight restriction in fuel return can cause no fuel delivery along with requiring a full flow to the pump.
