Re: 1066 water in rear tires
Posted by Erik Dekeyser on July 06, 2010 at 08:44:22 from (216.208.243.75):
In Reply to: 1066 water in rear tires posted by Michael Sheik on July 06, 2010 at 04:52:53:
It sounds like there is still about one quarter full. Just bring the valve stem to the bottom and remove the stem it should blow the rest out. You might have to do that 2 or 3 times to get it all out. I have done that quite a few times and have no problem at all. Erik..
