Re: H Carb Bolt
Posted by old on July 06, 2010 at 08:49:41 from (4.245.2.204):
In Reply to: H Carb Bolt posted by chad504 on July 06, 2010 at 05:59:48:
Yep do as Rusty says but be sure you get a nut or 2 with the bolts so before you hack saw the end off you put 1 or 2 of the nuts on. Do that and then removing them helps clean up the treads so it will then screw in easier
