If old Hugh were still around, he'd extol the virtues of sucking those tires dry, removing all the iron, and hanging axle duals on it.
All tractor rears are a little bit "square." They're never perfectly round, and cheap tires can be pretty bad in that respect.
IMHO, the weight of the fluid forces the tires to flex and conform more. Empty tires will bounce.
Water balloon vs. air balloon... The water balloon will flatten out and roll smoothly across a surface, while the air balloon will bounce across the same surface.
BTW, the fluid doesn't "sling around" inside the tire. It will pool at the bottom no matter how much/little there is, and no matter how fast you go. The only way it will sling around and create an out of balance situation is if it's frozen solid.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
