Posted by glennster on July 06, 2010 at 14:58:09 from (76.224.13.189):
In Reply to: dual remotes on a h posted by sunaewayha on July 06, 2010 at 11:18:43:
down and dirty way , but the hydraulics will not be live is to use the belly pump, run one of the output lines to a remote valve and take the return line from the valve and use a pipe tee and connect it to the belly pump drain plug. then wire back the control rod so the lift all pump is full on. be sure to use an open center remote spool valve.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
