Re: Charging Problem 230 farmall
Posted by Janicholson on July 06, 2010 at 17:16:31 from (67.72.98.45):
In Reply to: Re: Charging Problem 230 farmall posted by Farmall Lady on July 06, 2010 at 12:23:15:
The F terminal is smaller than the A terminal.
To test output:
With the tractor running at 2/3 throttle, and every thing connected as the diagram indicates, watch the amp gauge and use a jumper (piece of solid copper wire with insulation removed 1/2" on each end) to ground the F terminal to a good ground (shiny metal) this will not hurt anything. If it charges, it may need to either have the VR grounded better than it is, or a new regulator. Jim
