Re: pto on cub
Posted by d. coleman on July 06, 2010 at 19:01:56 from (74.32.207.77):
In Reply to: pto on cub posted by hoopy on July 06, 2010 at 12:07:46:
just did a complete o/h on my cub, is the snap ring on clutch shaft broken or missing? the fwd.bearing is what holds the shaft in position. you put the transmission in nutural and remove the shifter cover bolts and cover by lifting straight up. the clutch shaft is the upper shaft. you should be able to get a better idea of what is going on inside trans. almost any repair on trans. requires splitting the trans. and torque tube and removal both differantials. good luck, d.coleman
