Re: 1945 Farmall B
Posted by gene bender on July 06, 2010 at 20:58:33 from (207.177.56.232):
In Reply to: 1945 Farmall B posted by james williams on July 06, 2010 at 09:48:02:
Remove the pins they will drive out. The problem will be removing the joint from the steering sector and the steering shaft. You will need some good heat on both ends. Both ends have a woodroff key. The replacement could have a different way of mounting just depends on where you get one. It will not be like the original and cost around 45 and up.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
