Posted by Calif. Farmall on July 07, 2010 at 00:14:41 from (75.60.60.140):
Hi- the differential side bearing races are worn and have been rotating in the side mounting cup. I can see it has worn metal away, is it OK to braze the worn spots and machine the bearing housing back to spec's so the races fit tight. I have a lathe that will handle the parts, Will braze be strong enough? Welding cast with nickel rod may make it hard to machine? I have seen great things done with brazing however will it stand up for the next few years? Any help would be great, Thanks Dan.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
