Re: 560 oil pressure
Posted by Janicholson on July 07, 2010 at 06:31:52 from (199.17.6.23):
In Reply to: 560 oil pressure posted by Redhendrix on July 07, 2010 at 05:52:55:
If using 15-40 oil it should stay above 50psi.
if using 10-30 over 40 is normal.
If using 30 wt single grade, I would put it at 40 as well.
Above 20 PSI will be OK
at Idle with 10-30 it could be 10psi without making me nervous.
Jim
