Re: Charging Problem 230 farmall
Posted by Brownie 450 on July 07, 2010 at 13:51:58 from (66.43.241.95):
In Reply to: Charging Problem 230 farmall posted by Farmall Lady on July 06, 2010 at 11:53:58:
Has the regulator been changed to 12-volts? If it has & the generator to regulator wires are correct, ground the regulator frame to battery negative post with a jumper wire. With another jumper wire, connect it between the battery positive post & the BAT terminal on the regulator. This will by-pass any wiring problems. If possible, use an ammeter in your jumper wire to read current flow. If this test doesn't show any results, the regulator could be suspect.
