Re: More Dumb F 12 Questions
Posted by John M on July 07, 2010 at 14:01:52 from (67.231.160.184):
In Reply to: More Dumb F 12 Questions posted by Bill Copeland on July 07, 2010 at 09:33:56:
Yes, that Tee has a small hole in it. If its clogged it can cause it to run rich. You set the float with the top off of the carb. I set mine dead on to spec and it was still too rich, so I put an extra gasket on the seat, and drilled the hole out in the tee just a little bit, and started running Autolite 3077 plugs. Shell start on the second crank 9 times out of 10.
