Re: 1086 seal
Posted by Owen Aaland on July 07, 2010 at 16:01:02 from (65.161.86.20):
In Reply to: 1086 seal posted by Zachary Hoyt on July 07, 2010 at 05:48:59:
tomturkey said: (quoted from post at 08:48:59 07/07/10) I've checked thru the archives,most recomend that you have the special seal installing tool to replace the rear main crankshaft seal and wear sleeve. What does this tool look like? Are they available for purchase? I believe it is tool number FES 149-3. Could some one post a picture or tell me if it can be done without the special tool. Thanks for your help and support. gobble
The seal comes installed on the wear sleeve and is be installed as an assembly. The tool is designed to install them both to the correct dimention without damaging them.
http://www.agpartsltd.net/DETAIL.asp?PART=830429
