Re: H housing and gear that bolts to engine for distributor
Posted by Owen Aaland on July 07, 2010 at 16:35:32 from (65.161.86.20):
In Reply to: H housing and gear that bolts to engine for distributor posted by thumbanger on July 07, 2010 at 09:45:19:
The front gears only need to be timed if you are using a magneto. Even then it is possible to install it from the rear and get it timed correctly.
For a distributor just install the drive and then make the timing adjustment when you install the distributor into the adapter housing.
For a magneto turn the engine to TDC on number 1 compression stroke. Use a mirror to locate the timing mark on the front of the camshaft gear. Mark the tooth (or two teeth if the mark is between teeth) so you can see if from the back side of the gear. Locate the mark on the driven gear and match it to the correct teeth on the camshaft as you install it.
