Re: H and M clutch
Posted by Janicholson on July 07, 2010 at 19:42:01 from (67.72.98.45):
In Reply to: Re: H and M clutch posted by TDM on July 07, 2010 at 17:56:42:
None can allow the FW to be removed. It will allow the clutch driven disk and PP to come out.
At the end of the M production, they changed to a larger clutch which will not come out. Sm, SMTA are all not able to be removed. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
